Old 01-02-2025, 07:44 PM   #207 (permalink)
Logic
Borate Esters as used in Amsoil etc. ie: Certified Oils:
Borate Esters are used in engine oils to improve performance and protect against damage. They:
  • Reduce friction: Borate esters reduce friction in engine oils, which can help the engine run more efficiently.
  • Prevent sludge: Borate esters prevent sludge from forming in engine oils.
  • Improve lubrication: Borate esters improve lubrication properties in engine oils.
  • Extend oil life: Borate esters can extend the service life of engine oil and delay maintenance.
  • Improve thermal stability: Borate esters provide thermal oxidative stability.
  • Improve pumpability: Borate esters ensure low sludge formation and pumpability at low temperatures.
  • Improve anticorrosion: Borate esters provide anticorrosion at high temperatures.
Here's the formula:
Boric Acid + Alcohol = Borate Ester + Water
B(OH)₃ + 3 ROH → B(OR)₃ + 3 H₂O
NB
That the reaction does not only go one way.
Any water in the oil and:
Water + Borate Ester = Boric Acid + Acohol
That means that just about everyone already has a tiny amount of Boric Acid in their engines, with no ill effects as far as reacting with the rest of the additive package in the oil goes.
