Old 01-06-2025, 12:24 PM   #210 (permalink)
aerohead
' AMSOIL & Borate-Ester '
Originally Posted by Logic View Post
Borate Esters as used in Amsoil etc. ie: Certified Oils:
Borate Esters are used in engine oils to improve performance and protect against damage. They:
  • Reduce friction: Borate esters reduce friction in engine oils, which can help the engine run more efficiently.
  • Prevent sludge: Borate esters prevent sludge from forming in engine oils.
  • Improve lubrication: Borate esters improve lubrication properties in engine oils.
  • Extend oil life: Borate esters can extend the service life of engine oil and delay maintenance.
  • Improve thermal stability: Borate esters provide thermal oxidative stability.
  • Improve pumpability: Borate esters ensure low sludge formation and pumpability at low temperatures.
  • Improve anticorrosion: Borate esters provide anticorrosion at high temperatures.
Here's the formula:
Boric Acid + Alcohol = Borate Ester + Water
B(OH)₃ + 3 ROH → B(OR)₃ + 3 H₂O
NB
That the reaction does not only go one way.
Any water in the oil and:
Water + Borate Ester = Boric Acid + Acohol
That means that just about everyone already has a tiny amount of Boric Acid in their engines, with no ill effects as far as reacting with the rest of the additive package in the oil goes.
Yes, the AMSOIL, Signature Series, 5W-30, 100% polyalphaolefin synthetic motor oil has one part per million ( 1-PPM ) borate-ester.
In the 176 fluid ounces of oil in the test engine, there is:
* 0.000176-ounces of borate ester friction reducer
* 0.177056-ounces of Molybdenum disulfide friction reducer ( 1,006-ppm )
* 175.822768-ounces API Group V PAO oil and other additives ( 998,993-ppm )
Oil viscosity is :
250 cSt @ 0-C
104 cSt @ 37.8-C
10 cSt @ 100-C
3 cSt @ 150-C
No metal-to-metal surface contact during engine tests.
