Old 01-24-2025, 01:52 AM   #129 (permalink)
redpoint5
90 day: 46.97 mpg (US)
Originally Posted by Isaac Zachary View Post
It's all about cost. Wood is cheap. It's quick to install. It's also strong, so you don't need a lot of material to make the building strong.
It's like drywall and fiberglass. There are a lot of materials out there, both for structure, insulation and finished surfaces that are fire proof water proof, and better for a lot of other things too. But get water or fire in a modern house, and you have to rebuild the thing.
That's the general problem with sprinklers. I don't see your roof sprinkler idea doing much. Too much area to try to keep from catching on fire. Sprinklers work on the inside, but then you have to replace the carpets and drywall.
I want an erector set frame, which is modular, consistent, and has value after when the original house is dismantled. At bare minimum, it has scrap value, something wooden frames don't have. Wood is junk, and what cavemen use to barely exit the cave.
The rooftop sprinkler would extinguish any flame that came to rest on any surface, except interior ones. That is probably the main flaw, but preventing all shrubbery and bark dust from igniting is not nothing.
