Old 01-24-2025, 03:51 PM   #133 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Did a little more looking, and it seems embers igniting nearby shrubbery, and then catching window frames or eves on fire is the most common method of ignition.
https://www.frontlinewildfire.com/wi...catch-on-fire/
Looks like rooftop sprinklers can be highly effective.
In the Ham Lake wildfire in 2007, over 72 percent of the properties that survived the fire were fitted with rooftop sprinkler systems, and only one structure with a sprinkler system was destroyed. This demonstrates that when properly installed and maintained, rooftop sprinklers can significantly increase a home’s chances of surviving a wildfire.
...and the forest service says wildfire prevention is the cause of catastrophic fires.
The Following 3 Users Say Thank You to redpoint5 For This Useful Post:
freebeard (01-24-2025), Isaac Zachary (01-24-2025), Piotrsko (01-25-2025)
