Old 01-25-2025, 10:39 AM   #1 (permalink)
ademonrower
Ademonrower
Volvo 240 early series, headlight covers
The suggestion that someone on Ecomodder made that I should close off the openings around my headlights kept nagging at me, so I finally made headlight covers for better aerodynamics and headlight glass protection. Material: 4 mm Makrolon (polycarbonate), the stuff from which modern headlight glasses are made. Covering the heads on this model closes many gaps through which air can pass and cause drag. It also protects the ever more expensive glass 🙂 Comments and questions welcome...
ID:	35454   Click image for larger version
ID:	35455   Click image for larger version
ID:	35456   Click image for larger version
ID:	35457   Click image for larger version
The Following 7 Users Say Thank You to ademonrower For This Useful Post:
aerohead (01-25-2025), freebeard (01-25-2025), Gasoline Fumes (01-26-2025), j-c-c (01-25-2025), Joggernot (01-27-2025), kach22i (01-26-2025), Piwoslaw (01-25-2025)
