In Arcimoto's implementation there is a dial between the pedals and wheels. So you can dial it down and do all the work, or dial it up and the pedals become the throttle. Saves parts.
Yes; that's the std thing in E-bikes too, using cadence sensors or the more expensive torque sensors.
You do mean the Mean Lean Machine. Not the bigger 3 wheeler. (for others)
Here's the 'pedal if you like' Raht Racer I couldn't find.
