Old 02-08-2025, 02:01 AM   #5 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
IIRC the bleed hole is not just to de-air the system, but also to ensure the thermostat is not sitting in stagnant coolant, ie it is "up to date" with the current temperature of the engine?
Modern cars have sensora all over the engine and a heating element in the t-stat housing to open it when the ECU wants to, but those also should have a bleed hole as mechanical back-up.
The Following 4 Users Say Thank You to Piwoslaw For This Useful Post:
aerohead (02-08-2025), EcoCivic (02-08-2025), freebeard (02-08-2025), Isaac Zachary (02-08-2025)
