Old 02-15-2025, 06:32 PM   #10 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
1uzfe guys are using thermostat bleed port restrictors to increase total flow through the thermostat instead of the bleed port which increases cooling. I imagine you will see something similar. Although, i don't know if I've ever heard of anyone completely blocking it off. In my head blocking off the bypass will give you weird warm up and temp control until the thermostat opens.
https://adapt-lab.com/product/coolan...ss-restrictor/
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
K20ADC2R (02-19-2025)
