Old 02-24-2025, 10:43 PM   #1 (permalink)
freebeard
Gear-ratioed bearing
For your review:
2355 New Kind Of Drive?
2326 Universal 3D Printed Bearing That Works - Radial Cut
Suppose you had a zero-backlash thrust bearing that was also a fixed ratio single-speed transmission.
There would be a plethora of viable options, like the joints and wheels on your rideable quadruped robot.
Diagram at ?t=254 shows the diameters and angles that determine the ratio up or down.
Logic (03-02-2025)
