Some spinning Plasma from around 3min 10s here:
A different perspective:
NB the rotating cone here:
The center could be hollow Like this:
(No magnet/rotation. Corona discharge not spark. Low amps)
NB the thrust.
A similar swirling effect would happen.
Some more:
Now imagine that magnet is all intake tract bell mouth shaped, with a 3 to 1 ratio elliptical alla-ding-dong optimal shape, with the previous videos and the thrust. (and swirl..?)
On an engine with a see through intake manifold!
And hood!?
Then of-course I had to go look it up.
Effect of ozone on combustion of compression ignition engines
The full, normally paywalled paper:
https://sci-hub.ru/https://www.scien...g%20conditions.
"...the time of ignition shifts toward earlier crank angles...
...pressure curves also look a little smoother...
...enhances ignitability...
...Ozone addition is found to decrease ignition delay and increase cetane number..."
Pity about the marginal compression ratio decrease.
Yes; I've been reading pgfpro's threads.
A very mild, more of a talking point, turbo effect
Swirl..?
What happens when you follow that up with
As in a see trough (initially) intake manifold.
