Old 02-27-2025, 03:48 AM   #3 (permalink)
LostinTransit
Old But New Ecomodder
LostinTransit's Avatar
The "stickers" arrived on a sheet with the predesigned distance included. Template. All one needs to do is removed the base sheet from the stickers and using the clear sheet, transfer these onto the surface. it's like buying a vinyl sticker. You get a plain side and a transparent side peel back the one side, stick in place and peel away the clear side.
The longer pointed end would help direct the airflow into the center of these things and the double layer causes the flow disruption effect.. But will it be good enough. Not sure if flipping these around would more sense.. so that the double section is forward not reverse as shown in the photo.
This is one reason I asked above if these should be moved in close to a point in the middle or is there enough airflow interference with this setup. won't know till we get 23 sets of these and I do the pressure wash test.
One of my concerns is that the van has this molder lip edge as seen in the above image.. I suspect this cause some flow interference and I may end up placing these winglets within that molded edge and try to redirect air up and over that sharp edge.
Also, because these just stick to clean surfaces, I suspect one could place these on glass or rear window anywhere there';s a smooth surface. these won't stick to our texture bumper cover.
Rebadge left these spaced as you see in the picture, but can or could be moved around farther apart or closer or staggered. I guess one could select just the upward winglet instead of the upper and lower. I was going for a general airtab design.. rebadge can make you something different or include all uppers or all lower designed..
I'd like to see if anyone here would use these and just to see if these things would make a difference if placed in the correct location on their more aerodynamic car. My thing is, would these make any difference somewhere else on the van, like the hood or behind the wheels long the fender edge..
Again this is just my idea and rebadges design.. if anyone here has a better design contact rebadge. I've helped open his eyes to other sticker possibilities.
The Following User Says Thank You to LostinTransit For This Useful Post:
freebeard (02-27-2025)
