Old 03-06-2025, 03:05 PM   #6 (permalink)
Andyinchville1
What is the load/unload cycle? Do you back up to a dock or use a ramp and hand truck?
Suppose you could swing the door open only about 90-12 or 78 degrees. That would accommodate a fixed boxed cavity rather than a trailer tail.
The flush, potentially curved, surface would improve over the step and gap of a hinged solution. Not yet sure what would happen across the top.
Hi
Typically when I get to a job I fold the doors all the way back only because it makes the van overall narrower and in some places I'm actually parked off of a roadway next to a sidewalk so it wouldn't be good necessarily to just flip the door open 90° I guess it is relative to the long part of the van ... I suppose in theory I have the option of leaving the door lengthwise open and not fold it back partially but then it's the book tail is four or five feet long that would still stick into the roadway four to five feet which would not be really doable
Granted most of the time there's plenty of space but there are a few stops where I have to parallel park and having the extra hanging out in the road would not be good
Also I guess in theory if I left the boat tail being solid and not movable then it would make parallel parking difficult even from the start because it would be an extra presumably four or five feet or more maybe?
The man in the picture is actually my shorter Sprinter van I only use that one as a backup in a pinch because life is actually easier using my longer sprinter van because it has more interior volume so I don't have to worry about running out of space and having to unstack bread and restacking it later Etc
So basically having said that I'm thinking that it has to be foldable more or less and not fixed ....
I did run across one other interesting method for better aerodynamics on the road but I'm not sure I follow how exactly it works but here's a picture of another system that does not involve an entire tale but this company calls it the utility aerodynamic tail 2
I'll see if I can attach a picture on that basically all it seems is a small ramp that I guess somehow reduces drag? I say a small ramp it looks to start flush and then it raises up a little towards the back but I'm not really sure I understand why that would help but I guess they claim it does .... If that's the case that would even be easier to implement than a trailer tail but I have some doubts about that because I really haven't seen that many of those systems around whereas I've seen a lot of trailer tails on tractor trailers and there's actually been a lot of reports where it helps miles per gallon to the tune of about 5 to 6%
Anyways here's a picture of the other system that I found for trailers that could maybe be ultimately used on a van
Pic
2003 Jetta TDI Wagon, 5 sp, 210K miles, Stock.....for now!
