They are reliable for blind installs (where you cannot reach the other side to attach a nut etc) but you have to follow the instructions to the "t" and make sure the bolt you screw into them are not over torqued or you run the risk of loosening up the threaded part previously installed ... I have some installed to hold a skid plate on my car ... I did use anti seize so I am sure to be able to loosen the bolts installed later
2003 Jetta TDI Wagon, 5 sp, 210K miles, Stock.....for now!
