Old 03-17-2025, 08:21 AM   #5 (permalink)
paniwew
Rivet nuts are definitely a game changer for body mods. They provide a strong, removable mounting point and work well if installed properly. Just make sure you're using the right size and material for your application—steel rivet nuts hold better under stress than aluminum. As for loosening at highway speeds, using thread locker or lock washers should help keep everything secure.
