Originally Posted by Logic
Hmmm... With the compression ratios pgfpro runs I wouldn't be surprised if it did run on diesel too with the pre chambers blocked off.
The conrods etc might be a bit too light though.
(I get the impression compression ratio talk is avoided here to avoid a whole lot of: "Impossible! Lies!" hoo-ha BS.
Remember it's adjustable via the turbo boost and 2 AF ratios here)
It definitely could run on diesel in the high compression engine V2 version, but my focus is petrol and solvents.
Your 100% correct on given the compression ratios.
I decided to make a video on the compression ratio in the future and take advantage of visual aspect.
