Old 03-30-2025, 01:13 AM   #569 (permalink)
cRiPpLe_rOoStEr
If I were 100% sure you wouldn't risk ruining the engine trying to run on Diesel fuel, I would be curious to see it running on Diesel. But anyway, since you're more into testing it with solvents, I guess you already gave kerosene a try.
Originally Posted by Logic View Post
Hmmm... With the compression ratios pgfpro runs I wouldn't be surprised if it did run on diesel too with the pre chambers blocked off.
With port injection? No way. Unless he tried a similar approach to the Hesselman engines, which featured direct injection and spark ignition yet were meant to use heavy fuels such as kerosene and Diesel fuel.
