I buckled under the pressure when it got to the first video at #11. Was it after that?
Did I mention that I confuse easily?
Siameseing two transmission casings together is a long way from tapping onto the driveshaft. Any indication (OP?) of whether the hydraulic coupling transmits power one or two ways?
Well that video is just to give ideas as to where one might add (motor) power to a gearbox, but it does do a good job of explaining how they work and actually rely on friction not to grate.
And no; siamesing of casings isn't required.
That video simply illustrated the possibilities and that; just because there's a casing without holes/access,doesn't mean it cant be modded and sealed around a shaft etc to take power from a motor.
ie: "I don't see hole to stick the motor shaft through" isn't a good excuse!
Main Point/s:- Motor on engine: you lose out on regen because engine 'drag' and can't run pure electric.
- Motor on driveshaft: You lose out on taking advantage of the gearbox (you are lugging around anyway) that enables the use of a light, small, higher rpm = more efficient motor, and you need to find space for a big motor.
- Motor ahead of gearbox: All the advantages, except your clutch release bearing is working a lot more ( a good place for BA test) and you ancillaries aren't 'turning'.
One last thing: Possibly a wound DC rotor wins out of Permanent Magnets for overall efficiency, as it gives your motor a 'clutch' (conservation of momentum/coasting is most efficient) and enables the variation of the magnetic force which gives you a wider motor rpm range amongst other things.
They are also a hell of a lot cheaper!
