Old 04-06-2025, 09:11 PM   #1 (permalink)
Talos Woten
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
Arrow 2009 Toyota Prius with 45 mpg and live-in conversion
Own a piece of American automotive history!
I am selling Champrius, the Champion Camping Prius. She's a 2009 Toyota Prius with 325k miles on her, modified for fuel efficiency and converted for road life.
THE GOOD
* 45 real world mpg, meticulously maintained with records available
* Clean title in hand, two owners personal use
* Move-in ready, with bed, fridge, pantry, solar panel, and coach power
* Soundproofed + upgraded sound system; insulated + great AC / heat
* She's a fantastic conversation starter. You'll be a superstar everywhere
THE BAD
* She burns oil the higher the RPMs. Driven sedately = 1 Qt per 1-2k miles
* Two minor accidents and several failures, most repaired
* Every warning light is on, some for real conditions, others spurious
* She's been gutted and cosmetically looks ragged. Function >> appearance
* People will leech onto you while driving, taking pictures and video
Whether you want to live in her or just go glamping, she's a comfortable economical vehicle... for one person. Two people will have to get intimate.
I'm asking $9,000 OBO. I'll further deliver anywhere in the continental US, at $1 / mile from Aliquippa PA. Contact me at kimlumbard@hotmail.com.
Attached are some pics. The exterior and interior pics show things in the state you'll get it, i.e. mostly empty. The Door and POV pics show what it's like fully stocked with all my junk. That's *not* part of the sale; it's merely to show how much stuff fits inside. I'll include bonus stuff I won't need for my new vehicle, like sun shades, ODB II scanner, towels, sheets, etc. Feel free to keep or toss as you like.
Here's some more specifics for those interested.
MAINTENANCE SINCE 200k [with good until]
Synthetic Oil Change + Tire Rotation every 5-10k [331k]
Replace brake fluids every 50k [335k]
Check serpentine belt every 25k, replace if needed [335k]
Engine and Cabin Air filter every 20k [345k]
Fluid flush and replace every 50k [350k]
Tune-up / spark plugs every 50k [370k]
Low rolling-resistance tires every 80k [385k]
Replace transaxle / transmission fluids every 100k [400k]
New brakes every 100k [410k]
Spring cleaning [Spring 2026]
SERVICE SINCE 200k
200k Radiator Pump
205k Thorough cleaning, interior LED bulbs, radiator cap, fuel cap
205k Hybrid battery new connectors and hoses (removed smell)
205k Three rear cams with dash monitor, fix 12V short
210k v2.0 of the aeromods (Fall 2018)
220k v3.0 of the aeromods (Spring 2019)
225k Got my 50th ticket in Alaska, one from each state (flex)
230k Catalytic converter replacement
235k Oil Catch Can, cleaned manifold, throttle body, intake
245k v3.2 of the aeromods (Spring 2020)
260k LED headlights
265k Inverter pump + Water control valve
270k AC condenser and recharge
270k v4.0 of the aeromods (Summer 2022)
280k Control arm front driver and alignment
315k Wheel hub assembly front driver
320k Ignition Coil #4 replace
Maintenance and service documented in receipts in the glove box.
CONVERSION DETAILS
Foam twin mattress with cool comfort topper and airflow base mat
Back windows have bug screens and rain shields, along with one way vinyl
Alpicool C30 fridge in front passenger area, along with large pantry
Krieger 1100W 110V inverter, high wattage 12V splitter + fuse box
(3) Rural King RX-AGM24DP Marine AGM deep cycle batteries = 2 kWh usable
Coach batteries hooked up to alternator, isolated = powers while driving
180W BougeRV solar panel, warrantied to 2030 = +750Wh daily -250Wh fridge
Furman M-8X2 Merit Power Conditioner for clean AC electricity
WeBoost Drive Sleek cell booster, for signal/internet at remote campgrounds
Temperature controlled ceiling fan to cool cabin, with multiple manual fans
Insulated cabin and engine area, vastly improving comfort over stock
White tar on roof for solar heat reflection, ditto white vinyl on windows
Ample storage under bed, on bed sides, and under front fridge
This is all publically documented on my personal Instagram
https://www.instagram.com/kimlumbard/
AEROMOD HIGHLIGHTS [+mpg gain]
Tail reducing wake turbulence suction [+16%]
Smooth belly pans on the underside (with two metal cat shields) [+11%]
Moon disc hubcaps / wheel fairings (hubcaps *don't come off*) [+5%]
Tiny side mirrors with vortex generators [+4%]
Deflector for windshield wipers [+3%]
Removing the antenna, rear wiper, other deletions [+5%]
Diverging duct for radiator [?]
Public documentation on Ecomodder threads, like this one:
https://ecomodder.com/forum/showthre...0-a-40280.html
Let me know if you have any questions!
Name:	Exterior - Driver Profile.jpg
ID:	35569   Click image for larger version
Name:	Exterior - Front.jpg
ID:	35570   Click image for larger version
Name:	Exterior - Passenger Profile.jpg
ID:	35571   Click image for larger version
Name:	Exterior - Rear.jpg
ID:	35572   Click image for larger version
Name:	Interior - Dash.jpg
Name:	Interior - Pantry Fridge.jpg
ID:	35574   Click image for larger version
Name:	Interior - Twin Bed.jpg
ID:	35575   Click image for larger version
Name:	Interior - Under bed storage - passenger .jpg
ID:	35576   Click image for larger version
Name:	Door - Driver Front.jpg
ID:	35577   Click image for larger version
Name:	Door - Driver Rear.jpg
Name:	Door - Passenger Front.jpg
ID:	35579   Click image for larger version
Name:	Door - Passenger Rear.jpg
ID:	35580   Click image for larger version
Name:	POV - Lying Down.jpg
ID:	35581   Click image for larger version
Name:	POV - Privacy Towel.jpg
Champrius 4.0 is finished and up
FOR SALE.
Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
Stats from Champrius v3.2:
