Old 04-07-2025, 11:17 AM   #364 (permalink)
aerohead
' a bit over the original top speed '
Originally Posted by Logic View Post
Yes it does:
1st layer is a ceramic layer with 85% the hardness of diamond and complete resistance to the acids etc formed in old oil.
Subsequent layers transition from that to ironically bonded micro platelets akin to micro playing cards sliding over each other.
The layer is around 0.5 microns thick in total.
The coefficient of friction numbers are crazy low. Well into the 'Too good to be true' range. Something like 70X more slippery than steel-oil-steel IIRC.
So my initial test of a heaped tablespoon of Boric Acid, stirred into a coffee mug of boiling water went into a properly knackered engine where you couldn't see behind you for smoke and max speed was around 80, at which point it felt frighteningly like the engine was about to vibrate itself too destruction.
I poured it into the pre warmed engine and took off immediately.
I took it very easy as I knew the emulsion was doing nothing for oil thickness.
About 10km later I could feel the engine smooth out and a look in the rearview mirror revealed that I could see behind me once again.
Gobsmaked and in a state of shock and awe I gave it the gas and discovered that the engine had come back to life, was smooth as can be, and happily went up to a bit over the original top speed of the car.
(It was a little 1200, 4 speed Toyota that maxed out at 140KM/h. (rpm limited))
After that it went into my 2L Mazda and Dads 728 BMW etc-etc. all to great effect.
Except:
The Isuzu truck was no fun on an early morning winter trip as the damn engine just wouldn't warm up to the point where the heater would work!
NB!!!
VWs use a very fine sieve on the oil pump pickup.
The Boric ceramic coating gets in under the sludge that's inevitable in any engine fed a mixture of oil brands and the loosened sludge blocks the pickup, requiring one to drop the sump and clean the sieve.
Need some clarification specifics on this please:
1) The car 'exceeded' the original 140-km/h top speed.
2) However, Toyota had 'limited' the top speed to 140-km/h ?
3) 'rpm limited' by Toyota ?
4) Toyota 'governed' the top speed ?
5) or, valves 'floated' at around 6,000-rpm, much-cited by Toyota as a 1200cc engine 'redline'.
6) The valves in my 1994 Toyota pickup 'float' at 5,500-rpm ( 157-mph, 'gearing limited )
7) It's OEM top speed is 96-mph ( drag-limited )
8) It's gone over 108-mph on the flat with a 'tailwind.'
9) Same motor oil in all conditions.
A stuck thermostat might explain the ISUZU's inability to warm.
'Sludge' can be formed by the oxidation of oil-borne 'emulsions', acting as a binding agent for foreign particles, which can clog oil lines.
