Old 04-20-2025, 01:56 AM   #3 (permalink)
Appletank
vroom vroom
Appletank's Avatar
I thought I'd replied, but apparently I didn't hit Post. Apology if redundant.
Perhaps it does. A 3MPH delta might signal lost in the noise.
The theory with pulse and glide is be either at the peak of BMEP or at idle/off. Wandering around the slopes is less efficient.
The difference between 45-30 and 80-65 will be down to aerodynamics.
Yeah, I know that PnG exploits how the engine is more efficient when under load, then coasting to take advantage of the excess energy.
It's easy to tell 80-65 would use a bit more gas since the higher average speed will require fighting through more air, but my question is about the same average speed, but smaller deltas. So, 45-30 vs 40-35.
