Old 10-30-2008, 12:43 AM   #18 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
ConnClark -
Originally Posted by ConnClark View Post
They also measure volume of gasses emitted from the tail pipe and from that plus the ratio of emissions gasses they can calculate grams per mile or grams per HP.
If it were solely based on the ratio of gasses detroit would just pump fresh air into the exhaust instead of spending a grand on a catalytic converter.
And with this info as I have stated before, any leak in your exhaust system will benefit you on your emissions test.
But that seems to go back to the original question. The observed readings were identical for both tests.
Do you think that, based on the size of the leak + the accuracy of the readings yielded an accidental co-inky-dink of identical readings?
CarloSW2
American Solar Energy Society
