If your goal is heating and not aero, consider using a flat piece of anything and experiment with different cut out sizes and block the radiator directly, from inside the engine bay. If you are looking for aero upgrades then follow the suggestions of our fellow members.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
