Sadly, The MIazda is winterized a little differently. Fuel stabalizer added, tires pumped up, oil changed, put up on jacks, battery trickle charger attached, and fully covered, not to see the rosd again until spring.
I'll be driving the Dakota thru the winter. I have to change it's oil(just happens to be time), put 2x4 frame back into the bed--I then put buckets of water with snap on covers into it for ballast when snow driving--it's 2wd and would have no snow traction otherwise.
The radiator is already blocked, but I'd like to get my grille block made also. I'm also thinking that the radiator fan is going to be removed--I wanted to add an electric model anyway.
