Old 11-01-2008, 03:47 PM   #14 (permalink)
mopo3
Oil Tycoon
mopo3's Avatar
Siray - '09 Toyota Yaris sedan
90 day: 39.41 mpg (US)
Can the computer get every bit of data the car has at once? example the SG2 only outputs 4 things at once, could you receive all the info from the computer from all the sensors? if so, I'd want to write an Ethernet driver for Linux that would take the info in. I don't have a windows computer so that software isn't an option, and it doesn't make since to have a piece of hardware between the OBD2 port and the computer if your running Linux because you'd only need the software to tell the hardware what to send and receive.
