I found the info through google search cached pages, if anyone else is in my situation,
Use a flat-head screwdriver to open the box up by prying under the back lip. Now we'll connect some wires.
Connect +12V to the green terminal.
Connect Ground to the yellow terminal.
Connect VSS to the black terminal.
Connect the injector signal to the red terminal.
Close the box back up and run the RJ11 cable from the box to your MPGuino. When you plug both ends in, your MPGuino should turn on.
