Old 11-05-2008, 08:25 AM   #247 (permalink)
cmags
cmags's Avatar
Scoob - '05 Subaru Impreza Outback Sport SE
90 day: 25.28 mpg (US)
Originally Posted by tangomar View Post
Thanks. Sounds like a great deal.
Is it possible to display the amount of gas used during a trip? Sometimes I try to understand if it is better to go one way rather than another but they can have different length, speed, stop&go.
Yes, there is a trip setting. If you want to use the trip to track your tank, you will need to leave constant power to the 'duino. It does turn off the LCD after a timeout, and doesn't draw too much so you should be ok. You can reset the trip with a middle+left combination, and then confirm. It should track at least distance and average MPG for that trip. Check the wiki for more info.
