Old 11-05-2008, 09:20 AM   #248 (permalink)
Magister
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
When you shutdown the engine, the OBDuino detect it and save trip info in EEPROM, you can then switch off the board by unplugging it or put a switch on the +12V as I did.
There is 2 trips, one is used for tank and the other as a normal trip. Both can be monitored for fuel consumption, distance, fuel taken. For the tank trip it can also display the remaining distance you can drive on your tank.
2013 Hyundai Sonata Hybrid
