Old 11-05-2008, 05:00 PM   #8 (permalink)
Sean T.
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
well, after about a hundred miles of driving over the course of 2 hours... I came home with a trunk... no, CAR full of signs.
2 of them are actually too large to use as front air dams. Exactly the perfect length to reach each wheelwell, but they will need to be cut down about 6 inches to fit between the headlights and the ground.
One is the same size as the two mentioned above, but only about 3/4 as long.
Another is a very large square, it just BARELY fit in my trunk. When sitting on the ground, it easily reaches the car window.
I also got 4 small coroplast signs and a ton of plastic signs... not the garbage bag style, but almost like coroplast without the corrugation.
I'm so excited!!!
