Old 11-05-2008, 06:22 PM   #13 (permalink)
bestmapman
bestmapman's Avatar
Originally Posted by homeworkhome53 View Post
I found a fuse in a box in the engine compartment marked fuel which I jumpered around with an inline fuse and switch which I mounted beside the manual gear shift. Works fine, but I can still hear my fuel pump running when in the off position, so I went back and looked some more and found a relay that is marked fuel pump in the same compartment. I think what I'm killing is the fuel injectors. When I throw the switch the car continues to run for a few moments. Just long enough to take it out of gear before it loses power. The instrument cluster continues to run and the odometer continues to total which is what I was looking for. The lights stay on which was a biggy for night driving.
homeworkhome53
Do you have any pictures of the fuze compartments.
