Old 11-08-2008, 11:17 PM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Question Why is 'hard' braking bad for fuel economy ?
I have read several times that 'hard' braking and sharp corners are bad for your gas mileage.
Why is this ?
Is it just the fact that you have to accelerate once you have lost your momentum, or is there also some other factor.
Also, can you explain engine braking ?
I notice when coasting to a stop I will shift my automatic from neutral back to drive, and the car will shudder and suddenly slow as the engine 'catches ' and revs up.
Is this an example of engine braking ?
