Old 11-10-2008, 01:22 PM   #17 (permalink)
barbixy
Guest
Posts: n/a
bigger wheels/tires
Originally Posted by trikkonceptz View Post
I know 31" tires were not factory. Would you consider buying factory rims tires for the 4-runner? I know these jap bricks aren't meant for FE, but every little bit helps. Roof rack delete would be a smart start unless you use it. And if city driving is your use, then consider running half a tank of gas. My 4-runner has a 24 gallon tank, 12 gallons of gas may not seem like much, but anything helps.
Running sidewall max on the 4-runner has helped this thing glide like an ice skater, so best bet is get the wifey to practice techniques, I know the hassles, I'm trying to get the wife to do the same.
Good Luck
My understanding of running bigger than stock wheels/tires, is that it changes the speedo/odo, showing less or more miles than you've actually traveled, I don't think it changes the fuel consumption, you're just calculating fuel efficiency with a distorted benchmark.
