Old 11-11-2008, 11:49 AM   #3 (permalink)
order99
order99's Avatar
Ecodriving...Hummers...
Let's see how long it takes until they start Body Mods-hey, what DO you get when you lower the body, say, 24 inches, attempt to streamline a cube, replace the engine with the most efficient Diesel you can afford, change to thinner wheels and low RR tires, a heavier flywheel and a modified cruising gear, body pans and a tail?
Whatever you get, you could outfit a fleet of Geo Metros and VW Diesel Jettas with the $$$ required...
