Old 11-13-2008, 01:38 PM   #18 (permalink)
moorecomp
Originally Posted by jamesqf View Post
Why not keep the existing alternator, but wire in a circuit so that it only charges when you're braking? Should be fairly simple, just a relay that's energized by the brake light circuit.
And if you want to get a little more complicated, and have a second switch that lets you turn on charging when you're going downhill or coasting to a stoplight. You could also monitor battery voltage with a Scangauge or similar, and turn on charging if the battery gets critically low...
How about using an a/c clutch pulley on the alternator, connected to a relay, controlled by the brake light circuit. Kind of like running beltless but charges when you are applying the brakes?
