Old 11-13-2008, 05:04 PM   #86 (permalink)
solarguy
I am building a shop behind my house to build a super-ultra-hyper-miler. It will be a reverse trike, aka teardrop, 2F1R, slingshot, etc.
It will have a very small frontal area and a very good CD (duhh...). It will seat three people plus baggage, and seating will be in tandem, not side by side. So yeah, it will be quite long, about 16'. It will look a lot like an airplane fuselage, and the canopy will be either the most challenging part, and/or the most expensive part. It will have a small 3 cylinder diesel making approximately 25 hp max. I'm hoping for a 6 spd gearbox from a motorcycle with a final drive using a cog belt (much less noise and maint. than a chain and much more durable). The cog belt/pulley system will allow me to tweak the final drive ratio to maximize fuel economy. It will be rear drive. Single wheel rear wheel drive should also have lower friction losses. There's no good way to do front drive and keep the frontal area as small as I want.
It will very clean aerodynamically speaking. No rear views (cameras instead), no wipers, no grill for a radiator and very integrated lighting. The radiator will be a sheet of copper integrated into the belly pan with coolant pipes soldered to the inside surface. It will also have a simple valve arrangement to dump heat into the cabin for winter heat. No AC unless I break 200 mpg.
It will have 1.5" square tubing for the metal subframe. You mount all the mechanical goodies to the subframe, and 5 or 6 plywood formers to mount the foam/west epoxy/fiberglass composite body. Several of the major body panels will be entirely removable for access and maintenance.
For general character and appearance, think a cross between the Aptera and a T-38 Talon.
I am very conflicted about what to do for a front suspension. I don't want a bunch of struts and linkages hanging out in the airflow. The front track will be fairly wide for stability, say 55", but the wheels will be mounted out at the end of a pretty thin crossmember, which will itself have a cross section like a low drag wing. Nicely faired wheel pants that steer with the wheels.
I won't be able to start on it for 2-3 years, as I already have a lot on my plate. I will use that time to sort out the design details as much as I can in advance.
I'm leaning toward having a canopy made by this guy:
http://toddscanopies.com/prices.htm
For an engine, I am thinking about the naturally aspirated Isuzu 3 cyl diesel in the 23-27 hp range, like here:
Isuzu - The Leader Of Industrial Diesel Engines
My first order, back of the napkin estimates suggest 105-110 mpg cruising 70 on the highway. On the back roads, averaging 50 mph and being able to use some pulse/coast, this thing should return well over 150mpg.
It will use automotive low RR tires that come rated for 50psi or better.
Can't quite figure out what to do about a spare tire...
I estimate the grand total for materials at under $12,000.
Finest regards,
troy
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
