Old 11-14-2008, 12:17 PM   #50 (permalink)
TestDrive
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
> i suspect that it is diesel only because (i think) bully dog is a diesel performance parts company.
Could be, I'm not familiar with Bully Dog
> Does "increased transmission pressure" mean lower shift points, and does it mean higher risk of blown seals and leaks?
Honestly, your guess is as good as mine. Did I mention you need to talk to a transmission mechanic?
> I have a pretty good understanding of cars and engines, but auto trannies and diesels are my weakest points.
Doubt I'm more than a few paragraphs further along in the trannie & diesel service manual than you are.
In the spring (when i next need my truck) i will call up a TRUCK tranny shop and see what a fluid change, shift kit and oil change will cost me. Might make all the difference that I need...
I'd start by describing symptoms and you problems with symptoms and see what they suggest. If they say: shift kit + filter + fluid + not too much for labor = lots better, then go for it.
