Originally Posted by ATaylorRacing
I would use a dune buggy and put the drive train from a Metro XFi in the back....keep the wt under 1000 lbs with me on it would be easy and with less wt comes better FE.
Why build one when someone already has one
They are around 5000 bucks and if you had a titled geo metro you could use that since the engine in it is a slightly smaller G10 motor, just swap your motor and vin number onto the buggy, add lights and you are set.
Then just add a big fan on the back and you have what is possibly my next project
