I've seen the 2000 intake both improve and reduce power/FE for folks. A lot depends on the vehicle and the driver. Just like everything else. The newer style intake will fit the older 87-90 4.0, but the ports are differntly shaped. This usually results in lower perf for folks. The best head for the 4.0 is the 91-95 head (theres a specific casting number but I can't find it at the moment...).
With the parts XJ I have, the motor was going to be stroked (4.2 crank and rods, 4.0 pistons, slightly thicker headgasket makes it a 4.5 liter motor...) and the HO head was going to be used. And then the 2000 intake and a larger throttle body. THat was my thought process, thinking even with performance upgrades, I could maybe get some better FE for my ZJ. Rethinking this. Might modify an exhaust manifold for a small turbo (like off a 2.2 Chrysler form the 80s) to help in low RPMs but bypass for higher speeds. I just want a little extra oomph off the line, or at slow offroad speeds. This is still in the thought process.
Doesn't help with your cam question...
When it comes to Heroes, RENEGADES are mine!
