Old 11-18-2008, 11:53 PM   #7 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Duffman -
Originally Posted by Duffman View Post
Carlos,
This is the product you are looking for.
Canadian Tire
They also make stick on ones that are more square, mine is and I think it would fit on your car.
Thanks! It's in the same price range and is "designed" to be yanked off by hand (i'd probably use mittens) :
Features
* Ideal for engine blocks, oil pans, small engines, transmissions, drains, pipes, under cover applications
* Magnetically "sticks" anywhere you need it to heat oil, coolant, hydraulic fluid
* 200 watt - 120V AC
* Built in thermostat maintains optimum temperature -- will not exceed 250F (121C)
* Quick grip handle protects hands from heat
* Dimensions: 4-3/8 x 2˝ x H 3" (11 x 6 x 7.5cm) including handle
* 6" (15cm) cord
* CSA approved
Time to do some measuring.
CarloSW2
American Solar Energy Society
