Originally Posted by bennelson
4) Hybridize my S10 Pickup. Figure out a way to add an electric motor, controller and batteries to my existing gasoline vehicle. Drive around town on electric, use gas on the big, fast roads. Would need to figure out regenerative breaking to make it really efficient.
A common adaptation for this is to install an 8 to 10-inch electric motor inline on the main drive shaft. You can drive around using electric only by just putting the transmission in neutral.
You also have the option of using electric to supplement the ICE if desired.
Batteries could be installed in a box made inbetween the rear frame rails (if there's any usable space under there), or in a truck-bed tool box.
