Originally Posted by MazdaMatt
hm... i clicked the link and it says "make sure it fits your vehicle" and it tells me that it does not fit my 2k2 mazda protege5... is that just silly (because it is not oem bolt-on), or does my car maybe have different sized hoses?
As long as there is room in the engine compartment to mount it, you should be able to make it work.
Instruction sheet from KATs
(Take special note of points 2 & 3. Also be aware that it's best if the tank heater is mounted lower than the upper most hose connection.)
You might need
parts not included in the package (example: if your heater hoses aren't 5/8").
