Old 11-21-2008, 03:11 PM   #12 (permalink)
trebuchet03
MechE
The Miata - '01 Mazda MX-5 Miata
Originally Posted by Fast Guy View Post
The opening is pretty important if I don't want to melt my pistons. The radiator is behind the intercooler and both are vital to engine cooling and therefore engine life.
Keeping it within proper temps is vital to engine life... But is keeping the entire hole open vital to keeping proper temperature?
The case studies on this website show - absolutely not. With instrumentation, you can find the critical zone for a given environment. You're a bit of a special case because of the IC....
Question: Is the hood scoop directly ducted to the IC and radiator? Or, is it ducted and diffused (hood opening being smaller than the duct exit)? Keep in mind that turbulent air is MUCH MUCH more effective at conducting heat than that same air ramming it's way through there
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
