Old 11-21-2008, 04:07 PM   #1 (permalink)
brekko
brekko's Avatar
Romulus - '10 Honda Insight EX
90 day: 55.81 mpg (US)
Manual Cars and Popping the Clutch (to re-start engine)
Over the summer I recently got a new car, the current one I driver, and it was manual rather than automatic. I found that you can turn the car off and coast saving mass amounts of gas, not an entirely novel concept I know. But I am not totally aware as to what the possible negative effects of constantly turning off a car can be. I know the the starter can go bad eventually, not a cost I want to incur, so I found out about the idea of popping the clutch, which I have found can be done in any gear. Generally I turn the car off at around 50, coast to a desired speed, then pop the clutch in the conditionally required gear. I know little to nothing about the interworkings of a car, so might someone shed some light onto what problems this could cause if any?
dude, you're going 50 on I-75.
