Old 11-21-2008, 06:26 PM   #11 (permalink)
some_other_dave
Originally Posted by dichotomous View Post
...when going faster the pressure there would push (or pull from the vaccume behind) the leading edge down for more downforce (and drag, and stability)....
Therefore raising the pressure, causing the spring to push the device closed, thereby dropping the pressure, pulling it open again... Lather, rinse, repeat!
"Flutter", "un-damped oscillation", call it what you will. At the very least the noise will be quite annoying, and the vibration and change in lift and/or downforce could be outright dangerous. Not to mention the beating the moving parts will take, possibly leading to them failing.
I don't think I'm in favor of the design. If it were just an electric motor, now, that's another story. But an un-damped spring is just asking for trouble IMHO.
-soD
