hi Orange, do you have usb and 12 volts connected? (just curious, probably wasn't designed for both at the same time)
If usb works, and 12 volts through the regulator circuit doesn't, then your onboard regulator circuit is funky. Take a voltage reading to ground on the other side of the diode, on the regulator input and on the output to help isolate the problem.
