Thread: DIY heat pump??
Old 11-22-2008, 11:11 PM   #31 (permalink)
Xringer
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Originally Posted by duaneb9729 View Post
the expansion valve is a device that meters the flow of refriderant to allow for the maximum amount of cooling/humidity removal.
conradpdx, very little copper is involved in a in ground heat pump system, lots and lots of pex pipe is used for the transfer of heat from the ground to the heat pump.
i personaly have a carrier air to air heat pump, rated at a 16 on the seer rating scale and mated to a two stage variable speed 95% efficient furnace, this will be my first winter with a heat pump.
i have the controls set up to change over to the furnace at 30 degrees, air to air heat pumps are way better than they used to be. but still have a ways to go, i am experimenting at my own home, i am a heating and a/c contractor.
and as the technolgy improves we will move into the ground source heat pumps today it requires a very very large investment and so far would be a wonderful investment for the next home owner! but yes they do work
one of the troubles with converting a window unit to use as a heat pump, is what to do with the excess refriderant and installing the reversing valves and other electronic controls, a very expensive task and possible for an experianced heating person to do but with much effort.
How has that 30 degree setting worked out for you this month?
I'm seeing a lot of days in the 30s up here (near Boston)..
It's been down to the 20s too this week. Making me think
about a ground loop..
So, how is the Home experiment going so far??
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
