Old 11-23-2008, 01:18 PM   #7 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
with a vehicle that old I would go over the whole drive train and do a tune up if you have not done this already, change tranny fluid, adjust the injection pump, check wheel alignment, get the narrowest high pressure tires you can find, find out your rim weight and see if there are any newer lighter rims out there, use synthetic oils, foam air filter, larger element oil filter.
