Old 11-25-2008, 11:29 PM   #72 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
The nice thing about fine mesh, like cottonweave, steel wool, most canvas meshes, is that they stabilize airflow before allowing it to pass... which means that while MOST air passes over it, the part that doesn't will be stable and smooth, which cuts down on airflow significantly over an open hole, but still allows enough air to exchange some heat if necessary.
