Originally Posted by Xringer
The reason I would want to do this: To allow me to shift into 'N' and not have
any Engine braking.. And, be able to enter Fuel-cut-off..
Without engine braking, I could get longer & faster coasts..
Plus, I'm still thinking of using a small ICE-Assist motor (Weak-Hybrid)
and no ICE braking would allow for nicer Re-Gen..
I like the idea you had for the Cruise Control, but what you are describing in this second section is the equivalent (though much more complicated) to installing a kill switch. If your car goes into Cut-off in neutral, it would shut off, it would not be able to keep turning without the assistance of the tranny to rotate it.
