alright scratch that. found the numbers
It takes 165 KWH or 5 GGE(Gallons of Gasoline(or) Equivalent) to refine gasoline. if thats coal powered only its 330 lbs of CO2 per gallon of gasoline. if it follows the national average then at least half the energy is from coal. so just 150 lbs of CO2 per gallon. . .
so 150 lbs is less than 20 lbs of CO2 my car can possibly produce per gallon.
