Old 11-26-2008, 09:44 PM   #39 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by Christ View Post
You assume, by this statement, that all cars are OBD-2... not all cars have a post cat O2 sensor, and even a large number of those that do, only use it to see whether the catalyst is actually doing something, not to adjust the fuel/air mixture.
IIRC, it wasn't until the advent of OBD-2b that the post-cat O2 sensor's signal was used to help adjust AFR in comparison to the signal from the pre-cat sensor.
Even then it still wouldn't get hot enough over warm up. We need obscenely rich, like unburnt gas all the time, to heat up a cat to the point where it's damaged. Not just a little richer during warm-up. At least AFAIK.
